hotpoint oven door
  • #67939
    ganoble
    I have fitted two new hinges to my top oven door on my Hotpoint double oven.
    The door will not remain open as spring closes it, also there is a fairly large gap Approx 6mm at the bottem when closed.The other part of the hinge fitted to the oven both look good.
    Can anyone help
    Geoff Noble
    #369099
    Washman
    Re: hotpoint oven door
    You forgot the most important thing, the model number and also the part numbers of the parts you fitted. then we may be able to help you.
    Washman
    #369100
    ganoble
    Thanks for return mail
    Hotpoint BD31
    Hinges COO199565
    Regards Geoff Noble
    #369101
    don
    Unfortunately there are too many versions of that machine to correctly identify the correct parts. Can you post up the s/n and the commercial code please which are on the sticker behind the main oven door.
    Don
    #369102
    ganoble
    Hi Don
    The sticker is not very clear best i can see is Seial No 42.1.00020 nothing else visual
    Regards
    Geoff Noble
    #369103
    don
    That’s a nuisance to say the least 😉 in that case you will need to look at either the top or the rear of the oven for the model number.
    If not pratical can you post up any pictures of the old hinges which some kind person on here may recognise?
    Don
    #369104
    ganoble
    Hi Don
    Have looked closely at the new and old and there is a slight dimensional difference approx 2mm from the centre of the pivot pin to the slot which locates the hinge on to the main oven Also new has a locking bracket that pivots into locating slot
    Hope this is clear
    Model No BD31
    Geoff Noble
    #369105
    The hinges you need for the Top Oven Door are = C00223945
    The ones you ordered fit the Main Oven Door. 😉
