Hotpoint Oven overheats – element won’t switch off/maintain the preset temperature
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Hotpoint Oven overheats – element won’t switch off/maintain the preset temperature
  • #95558
    Panthro
    I’ve a Hotpoint SE100PX – the oven will continue to heat an not stop and maintain the set temperature. I’ve replaced the temperature probe and both thermostats but the problem persists. Could it be a relay or something else?
    I
    #460737
    if a relay had gone I would expect the element to glow all the time unless the unit is turned off but can be certain
    if you leave the unit will it ever stop heating ?
    don’t know the unit but normally there is an indication on the display that it has either got to temp of it is getting hot. have you got any indications of this type ?
    bear in mind this unit is over 10 years old and if the board is faulty its likely it come un-programmed making it a manufacturer only repair
    dave
    #460738
    Panthro
    The display shows the oven reaching temperature, but it just continues to heat (the door even locks as it hits the self clean temp range). I can see the element at the rear continue to glow
    #460739
    you could trace the element wires back to the board, find the relay and see3 if its stuck by measuring with a multimeter. if yes happy days if you can source and solder a new relay in
