Hotpoint Oven SA2540HWH error code F01 AND F24.
Home Forums Trade Technical & Spare Parts Forums Hotpoint Oven SA2540HWH error code F01 AND F24.
  • #103532
    ashfordkent
    Hi all. Not been out to this 4 year old Oven in white yet, just looking for a bit of advise. Customer says getting error codes F01 AND F24.
    Any help b4 I go much appreciated thanks
    #493494
    ashfordkent
    Follow up. I Got this In an email from customer: Whilst cooking the fault f01 appear on the display of the oven. Then a little while later F24 appears after. We then have switch the orange power switch off then the faults clear.
    #493495
    well have no access to units that new but on older units
    F24 is a fan error in either fan
    and fo1 almost covers everything else
    you would need a code reader to get the sub code to narrow down
    Hollytree_Technical
    I have got the error codes for this model (must have been one of the last that I was able to download before I lost access). [TABLE=”border: 1, cellpadding: 1″]
    [TR]
    [TD]Code[/TD]
    [TD]Subcode[/TD]
    [TD]Description[/TD]
    [/TR]
    [TR]
    [TD]F01[/TD]
    [TD]1[/TD]
    [TD]Main Board Probe Short Circuit[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]2[/TD]
    [TD]Main Board Probe Open Circuit[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]33[/TD]
    [TD]Electrical Signal Lost/Master Relay Fan Opened[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]34[/TD]
    [TD]Electrical Signal Master Relay Fan Short Circuit[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]48[/TD]
    [TD]Drive Master Relay Heating Elements Blocked[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]49[/TD]
    [TD]Drive Master Relay Fans Blocked[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]50[/TD]
    [TD]Common Master Relay Blocked[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]51[/TD]
    [TD]Pilot 1 Master Relay Door Lock Blocked[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]144[/TD]
    [TD]DS Circuit/Divider Analogic Input Out Of Range[/TD]
    [/TR]
    [TR]
    [TD]F24[/TD]
    [TD]113[/TD]
    [TD]Cooling/Upper Fan In DIODO Mode[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]114[/TD]
    [TD]Cooling/Upper Fan In Short Circuit[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]115[/TD]
    [TD]Cooling/Upper Fan In Open Circuit[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]116[/TD]
    [TD]Cooling/Upper Fan – Feedback Doesn’t Work[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]118[/TD]
    [TD]Cooling/Upper Fan In DIODO Mode + Master Relay Blocked[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]129[/TD]
    [TD]Central Fan In DIODO Mode[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]130[/TD]
    [TD]Central Fan In Short Circuit[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]131[/TD]
    [TD]Central Fan In Open Circuit[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]132[/TD]
    [TD]Central Fan – Feedback Doesn’t Work[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]133[/TD]
    [TD]Central Fan – Generic Problem[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [TD]134[/TD]
    [TD]Central Fan In DIODO Mode + Master Relay Blocked[/TD]
    [/TR]
    [/TABLE]
    Hope That Helps
    Jem
