Re: Hotpoint oven SH33X Thermostat & Regulator
The temp dial for oven set to 200 C and only reaches 140 C. Thermostat clicks in and out. I have changed the stat. In the instructions it says its controlled
Fan working fine.
From manual:
Starting the oven
1. Select the desired cooking mode by turning the
SELECTOR knob.
2. Select the desired temperature with the VARIABLE GRILL
knob. See the Cooking advice table for cooking modes
and the suggested cooking temperatures (see Cooking
Modes).
3. When preheating is ?fnished, the THERMOSTAT indicator
light will stay on: place the food in the oven.
4. You may do the following during cooking:
– change the cooking mode by turning the SELECTOR knob.
– change the temperature by turning the SELECTOR knob
http://kitchen.manualsonline.com/manual … s.html?p=3
