Hotpoint oven turning off when I open the door
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Hotpoint oven turning off when I open the door
  • #100484
    Peter12
    I have had a Hotpoint oven S19 891 SP IX with a touch screen control panel for about 2 years. When I am cooking and open the door the blast of heat and steam turns the oven off. This happens even when I have the key lock activated. It used to happen very occasionally but now happens almost every time I open the door. Any thoughts. Thanks
    #480819
    well there is a service bullitin on this so its a know problem
    it involves changing one of the user interfaces ( which ever is causing the problem)
    it gives part no 480121102685 (C00314591) for the part
    can only find it on ebay at £130 and there are 2 of them in the unit and either or both might be causing your problem
    At 2 years old I would talk to hotpoint as i would veiw this as a manufacturing fault but not sure of their interpretation
    if not you may be able to go at the retailer under sales of goods act
    Peter12
    Thanks for your reply. The retailer went out of business over the lockdowns so Hotpoint it is! Is the service bulletin easily accessible?
    #480821
    andyjawa
    Presume if the cooker/oven is 2 years old the part should be under a 10 years part warranty if it was registered just after purchase. If so get in touch with Hotpoint. Though my dealings with this shower are a moot point.
    #480822
    andyjawa
    ooops! Are a moot point.
