Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Hotpoint oven UY46K Main oven door hinges
- This topic has 7 replies, 2 voices, and was last updated 9 years, 10 months ago by
grooster.
May 26, 2016 at 5:10 pm #88400
grooster
ParticipantHi,
I need a pair of main oven door hinges for a customer that has phoned this afternoon.
The model is UY46K Serial no according to the customer is 31100079.
Its a bit confusing as to which hinges are the ones I need online. If anybody knows the correct part numbers it would be appreciated.
Thanks as per usual for your help.Nick
May 26, 2016 at 6:36 pm #437946iadom
ModeratorRe: Hotpoint oven UT46K Main oven door hinges
Is it a UT46K or a UY46K?
Bad news if it is a UY46K, there are three versions of UY46K, the commercial code is needed to ID correctly.
Unless you can find out if it is a UY46K, a UY46K Mk2 or a UY46K Mk2(T)
The last two have a different hinge to the UY46K. π
May 26, 2016 at 6:44 pm #437947grooster
ParticipantRe: Hotpoint oven UY46K Main oven door hinges
Where will the customer find the commercial code? I presume its on the back of the machine where the customer canβt see.
Its an hour round trip to this machine, the customer just read everything off the sticker inside the door. He never mentioned MK2 or/and (T)May 26, 2016 at 9:24 pm #437948iadom
ModeratorRe: Hotpoint oven UY46K Main oven door hinges
The commercial code should be on the rating plate on the front but the Hotpoint ones often fade or peel off.
The commercial code for the UY46K is 031634
for the UY46KMk2 it is 053613
for the UY46K Mk2(T) it is 045313Those codes will be part of a slightly longer 11 digit number often with several zeros at the end. The commercial code is usually the 3rd to 8th number of the larger number.
May 26, 2016 at 9:32 pm #437949grooster
They’ve read me the model and serial number from the sticker inside the door so I’ll ask them if there are any other numbers on there. It may be the rating plate your talking about, fingers crossed. How many numbers do they usually have?
May 26, 2016 at 9:33 pm #437950iadom
Just edited my post above. π
May 26, 2016 at 9:46 pm #437951iadom
Just in case you manage to find out the correct model, the part number for the UY46K is C00223945.
For the UY46K Mk2 and UY46K Mk2(T) it is C00196304.Jim.
May 26, 2016 at 9:57 pm #437952grooster
Your a star Jim. I really appreciate your help with this pal.
All the best
Nick
