Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint Plastic pulley/belt
- This topic has 7 replies, 5 voices, and was last updated 19 years, 2 months ago by
maltheviking.
January 12, 2007 at 8:33 pm #24086
maltheviking
ParticipantAnyone having a problem with the platic pulley and belt being fitted to current HP/inds washers, I have been to one today to re-fit the belt, only to be informed by the customer that this has happened 3 times under Gtee. Hotpoint eng, advised that they should watch the loading of the machine 😕 I advised the customer to get back onto HP and complain that the machine is not “fit for purpose” 😥
My opinion is that the pulley is “warping” under stress and throwing the belt off, the original metal pulley was far superior 😥
January 12, 2007 at 9:06 pm #200603bobokines
ParticipantRe: Hotpoint Plastic pulley/belt
Check to make sure that the black plastic mount is in place on the back lug of the motor. Had one only yesterday. The pivot was loose which meant that the motor shaft is not parallel to the pulley and hence the belt runs off the end of the shaft.
Bob
January 12, 2007 at 9:36 pm #200604maltheviking
bobokines wrote:Check to make sure that the black plastic mount is in place on the back lug of the motor. Had one only yesterday. The pivot was loose which meant that the motor shaft is not parallel to the pulley and hence the belt runs off the end of the shaft.
Bob
Hi Bob
I checked the alignment, all was OK
January 13, 2007 at 4:22 pm #200605iadom
ModeratorRe: Hotpoint Plastic pulley/belt
Have you tried a new belt. If I go to any WMA model, metal or plastic pulley and the belt is adrift I always replace it.
January 13, 2007 at 4:44 pm #200606maltheviking
Hi Jim
My first thought was to change the belt but I checked it every which way and then some, absolutly perfect. Re-fitted it and checked the alignment of the belt on the pulley, motor pulley, nothing. I cannot comment on the three visits from HP and if they changed it, I am sure they must have.
Mal
January 13, 2007 at 8:14 pm #200607bobokines
I would always replace the belt with a new one and remove one of the drum lifters to check for any foreign objects in the drum.
Bob
January 14, 2007 at 9:07 am #200608Simon46
Had this problem with indesit el belt. 3 times off. Replaced fine a year since.
S.
January 14, 2007 at 10:30 am #200609johnnyj
As a rule i lways replace a stretch belt, and as bob says check for foreign bodys in the drum, if you refit old belt you will prob’ly be back sometime to refit it again, as for the plastic pulley i’ve never had that causing it, thats not say this one isnt.
