hotpoint pyro oven
  • #103296
    suedehead1
    customer put the oven on for a pyro clean it tripped the fusebox. now it all lights up all touch sensitive buttons and display working
    but door wont open the catch is not visible, I have no model number and cant remove the oven because i need the door open
    to access the screws, it just ticks but wont work
    any ideas welcome
    #492530
    tripped RCD or MCB
    may have gone with a bang and blown everything if its the MCB
    anyway the catch is often at the top of most ovens but if you cant see it all you can do is warn customer of poss damage and take it from there. With a bit of luck you can prise ot the screws to get the oven out but it may damage the unit. Adding a match stalk to the hole will allow you to resecure if its fixed or replaced
    suedehead1
    hi, its a right fancy kitchen belonging to 2 lovely men and a chihuahua I think i will need to have a think but destruction is most likely thanks
    #492532
    Hollytree_Technical
    I have never been in this situation nor tried moving a lock manually but after looking at images of the possible lock (C00312491) I wonder if it would be possible to slip a right angled pick in above the door and move the locking bar over with it (I think that you may need to move it to the right and that you will need to try to get the end of the pick in between the button and the bar).
    Jem
    #492533
    suedehead1
    always worth a try thanks
