Hotpoint RD966J washer dryer fault
Home Forums Public Support Forums Help And Support Hotpoint RD966J washer dryer fault
  • #103204
    Tjb1976
    Hi I have an issue with my washer, RD966J It won’t heat up on certain programs and sits at 1 min remaining, I takes in a slug of water spins for a couple of cycles then pumps the water back out only to repeat this until I stop it, If I select a full wash and dry cycle it behaves perfect, I’d appreciate any help as this one has me stumped. surly all the sensors must be working to work at all?
    Regards
    Tim
    #492192
    i would check dryer heater for earth faults
    we get lots of problems like this when heaters have a slight leak to earth so check both heaters but the dryer is more likely
    Tjb1976
    That’s interesting because I bought it with a failed dryer heater. It would go down to earth as it warmed up. I’ve fitted a new one and that works fine. I’ll check the washer element to see how that behaves. Thank you for your reply
