Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hotpoint rf 175 bp
- This topic has 6 replies, 3 voices, and was last updated 15 years, 1 month ago by
slyp98.
February 10, 2011 at 9:04 pm #60955
slyp98
Participanthey guys , i had a luke at this f/f today and the fridge is fine but the freezer is not freezing its cold but not half cold enough , no ice at all do these have an evap fan , anyone have info on these models please muchas gracias
February 10, 2011 at 9:36 pm #344307johnnyj
ParticipantRe: hotpoint rf 175 bp
RF indicates normal bog standard non frost free models, FF indicates Frost free and all the fans modules etc, yours should just be controled by a thermostat so i would guess you might have a system fault.
February 11, 2011 at 10:42 am #344308slyp98
i checked system electrics from live and neutral on the plug to the relay and the o/l protection on the compressor all seemed ok there is nothing in the freezer so i checked the compressor and it was warm not very ,but not cold either , i checked the start capacitor also but when i was prising off the terminals connected to the relay it broke the relay in half , it was a perfect break though so i think some resin will stick it back together anyways is there a thermistor or thermostat in the freezer section of these that would cause a low temp fault to the freezer coil thanks
February 15, 2011 at 6:28 pm #344309slyp98
anyone have tech info , wiring diagrams on these models thanks kieran
February 28, 2011 at 11:33 am #344310slyp98
went back to this armed with some resin and a start capacitor , fitted a new capacitor and glued the relay housing back together , i put everything back on the side of the compressor and hey presto comp. fired up and is pressurising the system all is well in the sunny s.e.
March 1, 2011 at 2:54 am #344311gandh1
for the more ignorant of us non refrigerationy guys, why would a start cap fix the freezer, sold a few rf’s in my time, and as far as i knew, the fridges werent fed by the freezer as they were statics, surely anything to do with the relay start cap or compressor would affect both fridge and freezer???
March 1, 2011 at 9:46 am #344312slyp98
possibly a problem with the relay all along , i changed the start capacitor as the comp. was not kicking in , i’m not sure which of the alterations i made fixed it but its working fine !
