Re: Hotpoint RF64P Thermostat Wiring
Okay, unless you know what you’re doing stop right where you are before you do damage.
For a start you can’t alter the temperatures inside the cabinet outside of the spec range using standard stats and, even changing the stat to another type you’re not going to make a blind bit of difference to it, unless you want everything either frozen solid or not cooled.
Unless you replace with a pukka calibrated stat to the temperature range you desire you’re not going to get anywhere here with off the shelf, unmodified stuff.
Sorry if that’s not what you wanted to hear, hope it helps though even if it is to save wasting time. 😕
