Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Hotpoint RL64 Iced Diamond Larder Fridge – not cold
- This topic has 7 replies, 4 voices, and was last updated 21 years, 10 months ago by
admin.
June 1, 2004 at 10:12 am #5569
KeymasterI have a problem with the above model fridge.
The interior light works when the door is opened but the fridge (which is about 4 years old) is not cold. The thermostat is set to between ‘3 & 4’
I had a similar problem with a ‘Phillips’ a few years back, which turned out to be the thermostat.
Could this be the case and is it possible to repair DIY?
Many thanksJune 1, 2004 at 10:30 am #111867Dave_Conway
ParticipantRe: Hotpoint RL64 Iced Diamond Larder Fridge – not cold
It probably is the thermostat, the fact that you ask “Could this be the case and is it possible to repair DIY?” would suggest that you would be better off (and safer) to call and engineer.
The thermostat itself is around £20, so you shouldn’t be faced with a massive repair bill .
June 1, 2004 at 10:45 am #111868admin
KeymasterRe: Hotpoint RL64 Iced Diamond Larder Fridge – not cold
Thanks Dave
Good old Yellow Pages it is then!June 1, 2004 at 10:51 am #111869Dave_Conway
Or, post your postcode here, most of the members here are engineers 😉
One of them will be able to help.
June 1, 2004 at 4:00 pm #111870admin
Dave,
Thanks for your further reply.
Where on the site would be the best place to post my postcode to ask for the services of an engineer?
MikeJune 1, 2004 at 4:07 pm #111871Dave_Conway
There’s two ways, either just post it as a reply to this, or on the left use the “database” funcion and search using the first two letters of your postcode.
July 6, 2004 at 4:10 pm #111872NeilD
I have the same problem with my Hotpoint RL64. The thermostat is located within the interior light housing. If I unscrew this housing and tap the thermostat the fridge springs back to life. Once the temperature is achieved the thermostat cuts out and fails to restart when the temp rises again.
Is there anyone that can help? I am in the Solihull, West Midlands area.July 6, 2004 at 4:21 pm #111873Martin
NeilD wrote:Is there anyone that can help? I am in the Solihull, West Midlands area.
Most likely a faulty Thermostat, go into ‘Directories’ (on this site)and type in your postcode search to locate a local fridge engineer 😉
