hotpoint rla33 thermostat
  • #45695
    gav28
    have fit 2 x hpt2603481 thermostat still iceing up. has anyone else had problems with these stats?
    #286625
    johnnyj
    Re: hotpoint rla33 thermostat
    Morer than likely the tube the phial shoves into has moved, there was a problem with some of them moving causing them to freeze up.jj
    #286626
    helo_75
    but whats the cure? is it a write off?
    #286627
    gav28
    cheers thought so quality hotpoint?
    #286628
    johnnyj
    Sorry Helo no cure possible i’m afraid
    #286629
    helo_75
    thought so
    ive had a few of them ove written off, after countless stats and compressors
    #286630
    spimps
    (I don’t write them off you can take out the insulation at the back where the stat phial sits and reposition the phial so that is fastened to the evapoartor.Done it a few times now and works spot on,not origional spec of course,possibly better !
    I did post on this http://www.ukwhitegoods.co.uk/modules.p … ic&t=43429
    #286631
    spimps
    This one didn’t need a thermostat just repositioned the phial through the evaporator held down with a length of plastic.
    Hotpoint RLA64
    <img src="……” alt=”” style=”max-width:100%;” />
    AEG Santos having changed from electronic control to VT9 housed in a small splash proof plastic box from CPC
    <img src="
    #286632
    evo1
    feel the liner at the back, will be loose, you can push it in……..write off
    #286633
    spimps
    Always feel the liner first it’s fine on the htpt,although not alwways the case, it’s the thermostat phial location tube on this one has come away,gaffer tape would have done a better job when manufactured :rolls: write off,not this one.
    On the Santos the evap is 1/2″ forward from the back of the fridge so no problem there either.
    BG
