HOTPOINT RLA34 WILL NOT TURN OFF
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum HOTPOINT RLA34 WILL NOT TURN OFF
  • #34482
    Ian FIVE
    HI,
    I own a Hotpoint fridge RLA34.
    The fridge will not turn off do I have a problem with the thermostat.
    Can anyone help?
    The fridge is just over two years old.
    I thought it would last a bit longer.
    Ian FIVE. 🙁
    #242849
    cessna
    Re: HOTPOINT RLA34 WILL NOT TURN OFF
    When you say it doesn’t turn off do you mean the compressor is continuingly running? If so then it’s a stat problem.
    If you mean you turn the dial to the off position it is normal for the light to stay on but the compressor should not run.
    If it does run then its either the stat or the control wheel is slipping on the spindle of the stat and not turning it off.
    Don’t seem to sell the stat here but the part number is 2603481 – around £10-£14 depending where you get it from.
    #242850
    Dales-Electronic
    You could also have a problem with a lack of refrigerant, ie the temperature is not getting cold enough to cause the stat to switch the compressor off.
    #242851
    Ian FIVE
    Many Thanks for getting back so quick.
    I will have another look at it.
    Ian FIVE. 🙂
    #242852
    helo_75
    id be making sure the door is activating the light switch as well, not unusual for the door to drop, and not activate the switch
