does door fit properly?, does light go off when door closed?. Is it an exposed evaporator, if so can you reposition the capilary end to a different position on the evap plate?
Door seals ok , light goes off . This hasn’t got exposed evaporator the stat capillary goes down a tube within the insulation and goes in fairly easily to the same depth as original . Any more suggestions please .
Thanks for all help so far .
Geoff.
