hotpoint rla34p
  • #55296
    onecallpaul
    The fridge is icing up at the back even on low, I changed the thermostat and its still the same I dont do fridges normally so I’m a bit stuck ,could it be a relay if so does anyone know the part no cheers Paul
    #322884
    wizard
    Re: hotpoint rla34p
    Paul, probably the plastic liner has come away from the evaporator. It will look like a bulge in the back wall of the fridge, or if defrosted you can push on the liner and it will feel springy. Unrepairable I’m afraid.
    Wizard
    #322885
    onecallpaul
    Re: hotpoint rla34p
    Thanks mate new fridge then!
