Hotpoint Sa2844hix oven.
multi function oven fan oven works ok.
conventional oven (top and bottom heat). Bottom element heats up but top element doesent. When turned to grill setting the top element heats up. It’s not a dual element.
has anyone come across this issue before, and if so what’s the problem?
thanks
Darren
You may want to watch and listen carefully to it before you order a board as I have come accross a couple of ovens where they turn on only the bottom element till they get close to temperature then they will switch back and forth between the 2 but never have both on at the same time, I can only assume that it is something to do with energy efficiency and power draw.
