iadom wrote:😳 OOPS.
It darned well should be, its a very common fault on this ‘quality’ appliance. :rolls:
A11..Wash pump faulty or wiring / connections between pump motor
and module faulty.
I have the same fault, never seen it before.
You mention it being a common fault, can you tell me what causes it.
You say its motor or maybe wiring. Can you say what is more common?
thanks for the info. Problem is, if it doesnt do it while you are there and all tests ok. You have to go for board or motor and as both are expensive I cannot afford to get it wrong.
