Hotpoint sdk80 fault
  • #62515
    Kevinl
    This sdk80 is second hand but worked ok. It started to show various faults and appeared to boil the water after the drain pipe was feed directly into a drain rather than into a standpipe. Would not having the recommended head on the drain outlet cause pump or heater problems? After raising the drain pipe to the correct height does not fix the problem so I suspect that the damage is done. Taking off the right hand side it looks as if the water is not circulating. Any guidance would be appreciated. Thanks…..Kevin
    #350326
    Re: Hotpoint sdk80 fault
    No such model number. 😉
    #350327
    Kevinl
    Well spotted iadom. That should be sdw80. Thanks.
