Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hotpoint SDL510 Stopped Pumping
- This topic has 14 replies, 2 voices, and was last updated 5 years, 7 months ago by
Ash Kiwano.
August 16, 2020 at 12:01 pm #98184
Ash Kiwano
ParticipantHi! Looking for help with my Hotpoint SDL510 Dishwasher , it has started to flash these two lights and won’t drain the water, I usually hear a pump but nothing, I read online it may be a blocked waste pipe but I have used a wet and dry vacuum on it and there are no obstructions so I am now confused?
Thanks!
AshAugust 16, 2020 at 12:16 pm #471270electrofix
Moderatorcould still be blocked
if its jammed completly it will just be a faint hum which can be difficult to hearDave
August 16, 2020 at 1:16 pm #471271Ash Kiwano
ParticipantHi Dave
I’ve put the wet and dry hoover on the end of the pipe and can feel the suction from the bottom of the drain inside the machine so it can’t be blocked still.
I know the hum that you’re talking about which it usually makes when it’s draining but it’s completely silent now
August 16, 2020 at 1:20 pm #471272electrofix
Moderatorno you dont get it
if the impellor is jammed and cant move it will make a very quiet hum but you have to listen very hard to hear itDave
August 16, 2020 at 1:28 pm #471273Ash Kiwano
ParticipantOkay I’ll pull the machine back out, will the sound come from the back of the machine? Thanks
August 16, 2020 at 2:13 pm #471274electrofix
Moderatorthe sound will come from the pump and probably very faint
you can see the grey outlet hose coming off the pump
August 19, 2020 at 2:22 pm #471275Ash Kiwano
ParticipantHi! So I have the panel off and I can hear a very faint noise it sounds like a high pitch noise ?
August 19, 2020 at 2:41 pm #471276Ash Kiwano
ParticipantHere’s a photo of the underneath
August 19, 2020 at 2:42 pm #471277electrofix
Moderatorremove the pump and see if its jammed
there are normally plastic clips to lock it on
August 19, 2020 at 3:49 pm #471278Ash Kiwano
ParticipantIs that the white thing on the right in my photo?
August 19, 2020 at 5:14 pm #471279electrofix
Moderatorcorrect
photo a bit blurred but you can see the lock and pump twists and unlocksDave
August 28, 2020 at 11:47 am #471280Ash Kiwano
ParticipantHi!
so I took the panel off today and removed the motor and i couldn’t see anything wrong with it?
here is a video
Put it all back and started a cycle and again, would not empty, any suggestions now?
Ash
August 28, 2020 at 1:22 pm #471281electrofix
Moderatorno that looks good
well next thing i would have done is checked the pump windings
if ok i would then trace the pump wires back to the board and check continuity
then look where the pump connects to the board and trace the connections to the triac that controls the pump and look for circuit damage
August 29, 2020 at 7:25 am #471282Ash Kiwano
ParticipantHi Dave
I just want to say thank you for all your help, I’m not an electrician so I have no idea about checking circuit boards etc, I was just trying to save this from
being scrapped and calling someone out is going to be just as expensive as a new dishwasher.Thank you again
AshAugust 29, 2020 at 8:58 am #471283electrofix
Moderatorno problem
i was hoping it was glass in the pump as it normally is but you get the challenging one
