Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint SDL510G Dishwasher (36685980000)
- This topic has 8 replies, 3 voices, and was last updated 9 years, 6 months ago by
jontymox.
September 21, 2016 at 9:53 am #89363
jontymox
ParticipantGood morning,
Wondering if i can obtain some help with a fault on the above slimline dishwasher?
The fault is the appliance shuts down after around twenty minutes of perfect operation. (drains, fills, washes, heats) then it shuts down completely, (all lit lights go out) and cannot be switched back on.
My customer tells me that it will power up again after an hour or two, and i suspect the board, which recovers after this time?
However, i would like to know for sure as a replacement is very expensive, and don’t know if i should be looking at other causes.
jonSeptember 21, 2016 at 10:12 pm #441153electrofix
ModeratorRe: Hotpoint SDL510G Dishwasher (36685980000)
have you changed the socket its plugged into ?
September 22, 2016 at 6:48 am #441154jontymox
ParticipantRe: Hotpoint SDL510G Dishwasher (36685980000)
Good morning Dave,
No, but when the dishwasher shuts down, power remains along the flex.
I checked the above when the fault occurred to be sure.
jonty
September 22, 2016 at 8:47 am #441155electrofix
assume you have also checked live and neutral up to the board so i agree with you it does sound like a board fault
September 30, 2016 at 10:13 am #441156jontymox
I’ve just replaced the main board, and programmed it accordingly.
However, the dishwasher will not now switch on!
When programming the board, the panel lights all flashed at some stage of the download, which was successfully carried out.
I’m wondering if I’m missing something obvious, or haven’t done some procedure following the download?
The wiring to and from the display module is fine, so i wonder if this has failed for some reason?
jontySeptember 30, 2016 at 7:57 pm #441157kaibart
When you program a module you need to leave it unplugged for at least 2 minutes after programming the fault you explained in the 1st post sounds like the machine is going into standby so I would say module fault these new arcadia modules are a right pain
September 30, 2016 at 8:26 pm #441158jontymox
Thank you kaibart,
Possible new module fault?
jontyOctober 1, 2016 at 7:58 am #441159jontymox
Struggling with this one.
Not sure whether their is a problem with the new main control board, or if the display unit has failed. (looks ok/no heat damage)
I wish we could test such things conclusively!
jonty
October 2, 2016 at 9:48 am #441160jontymox
ParticipantHotpoint Dishwasher Board Programming Related Problem
Good morning all,
I’ve renewed the main board on the following: Hotpoint SDL510G Dishwasher (36685980000) but now it will not switch on.
The module was programmed satisfactorily, and completed the download with the solid green lamp on the reader illuminated.
However, the dishwasher will not switch on, and I wonder if I’m missing something obvious following the above?
I’ve checked the wiring to and from the display module, which is fine, together with the connections on the main board.
Now beginning if there is a problem with the new main board, or if a fault has coincidently developed with the display module…
Any help much appreciated!
jonty -
