Hotpoint SDW 60
  • #68145
    Muv
    Hi all
    Installed this ex display model for a friend…
    At first wash Pump out started fine…
    Did the wash, then pump kicked in as usual but thus time just a humming sound and no water coming out.. Am i right in thinking Jammed pump/ loose impellor?
    Also salt light flashes Although its full.. And lights 4&5 flash?
    Any thoughts
    PS lived the conference..
    My first, but definately not the last one i attend..
    Thanks to all
    #369985
    nigegt
    Re: Hotpoint SDW 60
    I know it sounds daft but is it connected under the sink and if so that fitting my be blanked off?
    Lights 4-5 is a time out fill error
    Nige
    #369986
    Muv
    Hotpoint SDW 60
    Yes all new connections installed, taken waste pipe off… Still no water out…
    Thanks for your help tho
    Re: Hotpoint SDW 60
    You have trade access Muv, moved thread to correct forum. 😉
    Drain pump is easy enough to get at, sounds like an obstruction, don’t get many impellors falling off these.
    #369988
    Muv
    Hotpoint SDW 60
    Ok thanks iadom
    #369989
    Muv
    Hotpoint SDW 60
    Well finally sorted the problem… Went to disconnect hoses in order to get a look at the pump, and when I removed the waste hose from sink connector… There was a black plastic bung. Wedged in the waste pipe… This was definitely not on the fitting connected to the sink .. As I double checked this beforehand!
    Can only assume it was fitted in the dishwasher outlet hose from the outset
    Anyway looks like first reply was correct..
    Thanks to all
