Our dishwasher (Hotpoint SISML21011P) has stopped heating water and drying. I have taken the heater out of the machine and checked the continuity and resistance. It seems that the actual heating element is ok but there seems to be a problem with the connection to the actual element. The image below probably helps to explain it.
There is no continuity between the two terminals (“A” and “B”), however there is continuity between “A” and “C” and a resistance of 28.5 Ohms. There is also no continuity between “B” and “C”, therefore I assume that the connection between B and C has failed which I find slightly strange. Should there be continuity between A and B? Have I missed anything or is a new heating element likely to fix the issue?
