Hotpoint Slimline 7801 not emptying
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint Slimline 7801 not emptying
  • #12979
    mathew
    My Slimline 7801 has been a good and faithful servant for 8 years or more.
    Sadly it’s not emptying the water now which sits in the bottom of the unit below the sliding tray.
    I’ve not put salt in for a while as we’re in Manchester UK and we seem to have reasonable water.
    Cleaning the filters hasn’t helped.
    The outlet pipe as originally installed was positioned incorrectly according to the manual for some time but that didn’t seem to cause it any problems all this time. I’ve now raised the height of the outlet pipe.
    I’d hate to lose the machine as it’s been brilliant up until now.
    Many thanks for any advice and guidance.
    Mathew
    #152438
    Simon46
    Re: Hotpoint Slimline 7801 not emptying
    When you start the program can you hear the drain pump running before the first fill? or just a hum?
    Regards
    Simon
    #152439
    mathew
    Hi Simon,
    I hear a fast ticking/clicking for about half a min. Then a hum joins in, the hum is like a gentle vibration.
    After 3 minutes much more noise as presumably the machine starts to fill.
    Cheers
    Mathew
    #152440
    No, as Simon46 was suspecting, your drain pump is jammed with something and needs stripping out and cleaning. No way is it a DIY job and I recommend you consult a local expert here : –
    Repairs@
