Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint stuck on tESt
- This topic has 8 replies, 9 voices, and was last updated 20 years, 1 month ago by
iadom.
February 12, 2006 at 4:18 pm #15596
ModeratorThis relates to models, WF620-630-640-645-720-730-740-745-860. Also some WD models
It is in fact a Demo mode.
There have been at least 3 versions of Demo Mode used on these appliances.Version 1(Production to- Date code 39 March 2005)
To Activate
1. From the Default screen of a programme, after switching the appliance on press both Start/Cancel and On/Off buttons together until d On appears in display.
2. Press the Start/Cancel button only and tESt appears in the screen (Temp & Spin symbols also appear)To Deactivate
Press the Start/Cancel button until all the console LED’s illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.Version 2 ( during Date Code 39 March 2005- to Date Code 42 June 2005)
To Activate
1. Same method as version 1.
To Deactivate
1. Simply press the Cancel button and the appliance returns to default.
Version 3 (During Date Code 43 June 2005 – to date )
To Activate
1. Press On/Off and Start/Cancel together with the top left option button until d On appears.
To Deactivate
1. Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
A later method that works with the Indesit variants as well.
Switch off at mains, press and hold On/Off & Start/Cancel buttons, switch mains back on, keep holding down buttons until Doff appears in display.
Thanks to hotpnt for that one.
These variations could explain why some of us have to make several attempts to clear tESt. 😉
March 20, 2006 at 7:13 pm #164213funkyboogy
ParticipantRe: Hotpoint stuck on tESt
new version of deactivating tESt…
if you get tESt message when pressing start…let it run through test mode (about 3mins) then when it says end.. press on/of,start/cancel together untill d off message appears…switch app of ,and when switch back on it should be ok….
just done this 2day…after trying all the other versions of deactivating test mode…July 31, 2006 at 7:17 pm #164214johno1998
Just did what you said worked a treat cheers 😆
July 31, 2006 at 8:14 pm #164215roy1
ParticipantAlso to cancel tEST mode, press the start+on button
with the door open then select off test demo.March 18, 2007 at 6:17 pm #164216helo_75
grrr i had a new wt machine do test mode
could i get it out of test mode? NO
new eprom and board was the only way
June 10, 2008 at 6:19 pm #164217Lawrence
Went to one today WD640 date code 37196066 stuck on test tried every which way in the fault code book no luck assume EEprom and board ?
LawrenceJune 10, 2008 at 7:56 pm #164218admin
KeymasterRe: Hotpoint stuck on tESt
Lawrence wrote:Went to one today WD640 date code 37196066 stuck on test tried every which way in the fault code book no luck assume EEprom and board ?
LawrenceSome of them cannot be resolved because problem it’s inside controler. Microcontroler has inside “ROM” program one sub-routine which can be recalled every time when you need or he is reading something wrong (like high power supply voltage).
Changing eprom does not resolve problem…
October 22, 2009 at 7:02 am #164219twinspark
ye s 😮 you will need a new board
December 30, 2010 at 5:14 pm #164220mvitorio
Similar to previous posts, but I found tEST displaying, so had to press cancel button until the default programme showed, before I could use the two button method to get d Off, and the machine working as normal.
