Hotpoint SY10X Oven Timer Dead Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint SY10X Oven Timer Dead This topic has 7 replies, 3 voices, and was last updated 8 years, 8 months ago by jontymox. Viewing 8 posts - 1 through 8 (of 8 total) Author Posts July 14, 2017 at 12:38 pm #91680 jontymoxParticipant Good afternoon, The above single oven’s timer is dead, so no functions working. I checked the terminal block, and all the associated wiring which is fine, so renewed the timer this morning. However, the unit remains dead, and I don’t know why. Is there any way of testing a timer conclusively, or should I suspect a faulty new unit? jonty July 14, 2017 at 3:01 pm #448963 MartinParticipant Re: Hotpoint SY10X Oven Timer Dead Is there power to the timer? Or maybe a connector block loose? July 14, 2017 at 3:16 pm #448964 jontymoxParticipant Re: Hotpoint SY10X Oven Timer Dead Hello Martin, The only live testing I’ve done is from the terminal block, which is fine. I’ve inspected the terminal block, and all the relevant wiring which are all good. July 15, 2017 at 7:29 am #448965 jontymoxParticipant Re: Hotpoint SY10X Oven Timer Dead Need to bring unit back to workshop, and wonder if there is a safe way of powering up the timer with the correct voltage? I cannot fathom why the timer is dead… July 15, 2017 at 8:19 am #448966 aqualectricParticipant Re: Hotpoint SY10X Oven Timer Dead Thermal cut out fitted to that oven – one shot type. Probably in line from the terminal block to the timer / selector switch. Hope that helps! Steve. July 15, 2017 at 9:42 am #448967 jontymoxParticipant Re: Hotpoint SY10X Oven Timer Dead Thanks Steve, Yes, that certainly helps… will test and let you know early next week. Regards, Jon July 18, 2017 at 4:42 pm #448968 jontymoxParticipant Re: Hotpoint SY10X Oven Timer Dead Have ordered a replacement timer, as TOC fine and power reaching unit. Update in a day or two. jonty July 19, 2017 at 8:12 pm #448969 jontymoxParticipant Re: Hotpoint SY10X Oven Timer Dead Well, I replaced the suspect new timer, and all was well. (Clock & all oven functions fine.) However, upon fitting timer permanently it was found to be “dead” again! Have re-ordered, and hoping for third time lucky…… jonty Author Posts Viewing 8 posts - 1 through 8 (of 8 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
