Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint t/d 1701 Liberator. Noise.
- This topic has 4 replies, 5 voices, and was last updated 20 years, 1 month ago by
leavemetogetonwithit.
March 4, 2006 at 12:18 am #16087
ParticipantI know how much you old ‘uns cherish your memories of these things. This one’s in very good nick still and drum bearings aren’t showing much slack. Noise seems to be emanating from that flywheel mounting area. It sounded a bit like a loose fan blade might have done but the fan is tightly mounted. Can’t feel any wear in flywheel or jockey wheel bearings. I’ve told the old dear to hang on for a week before going out to look for a new one. The machine looks robust enough to go for another ten years. Any ideas?
Serial no. is 81108/62. How old does that make it?
I won’t be around here much over w/end so hope I’ve given you enough info..
TIA,
Mike.March 4, 2006 at 12:49 am #167493Penguin45
ParticipantRe: Hotpoint t/d 1701 Liberator. Noise.
I’d be more worried if it wasn’t making a noise Mike! Transfer pulley bearing most likely candidate – no parts anymore of course, so it’s make do and mend time.
March 4, 2006 at 12:56 am #167494aqualectric
The phosphur – bronze bushes in the reduction pulley (2 belt thing) used to wear and turn in the worn pulley body. This sets up a vibration through the base. Quite often you would remove a pulley with no worrying slack and the bushes were ready to fall out. Could be that? Think it’s unlikely to be available anywhere – I haven’t seen one (as a spare) for years +++!!!
It would take all the metal used in 50 modern Merloni machines to make that part!! 😆
If it is a purple door bowl model, could be 30 years easy. Now that’s enviromentally friendly!! 8)March 4, 2006 at 7:56 pm #167495wilf
lots to be noisy! all of previously mentioned plus motor bearings which can be replaced from a bearing stockist. check tub front fixings (metal front) might need tightening
wilf
p.s. watch out for relay its gravity sensative!
March 4, 2006 at 10:40 pm #167496iadom
ModeratorRe: Hotpoint t/d 1701 Liberator. Noise.
If it is a purple door bowl model, could be 30 years easy. Now that’s enviromentally friendly!! 8)The frightening thing is, back then we thought they were poorly made, not up to the standards of the Empress. 😉 😆
My guess as to the age of a date code 62 would be around Feb 1974. 🙂 -
