Hotpoint T/D VTD60
  • #57600
    clivejameson
    This one had blown the safety stat…the vent hose was failry choked with fluff but to be on the safe side i replaced the stats.
    Unfortunately it stll gives an F13 error and aborts as soon as started. The heater is good and the circuits through the stats and heater are fine measured from the pcb connectors but still it won’t budge off the fault code!
    Does anyone have the test procedure for this one please? I’m kinda hoping running the test will reset the pcb?
    #331715
    BobHope
    Re: Hotpoint T/D VTD60
    Hi Clive,
    ive sent you some info.
    Bob.
    #331716
    clivejameson
    Thanks for that Bob 😀
    #331717
    clivejameson
    Just an update….on some serial numbers of this model the stats at the back are actually a one-shot and a thermistor!
    Good old connect gave me a standard cut-out kit 😕
