Is there a bearing kit to replace the wheel support system?
I’ve a few calls for these in the next week, what do i need. Young machines & customers complaining of roughness when you turn the drum by hand & noise when running.
Seamy wrote:Is there a bearing kit to replace the wheel support system?
The front bearing kit = 1703273 covers early (with wheeled support) and late (just nylon bearing pads). Also the rear drum shaft (1703079) often breaks up the rear bearing bush (Square shape = 1703014/Teardrop shape = 1703436). The pressure caused by the stretch belt is the main reason all this damage is caused!
