Hotpoint TC71 cutting out
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint TC71 cutting out
  • #38662
    md3k
    Hi there, new here looking for some guidance.
    I have a Hotpoint TC71 tumble dryer, its starts fine and runs for a random amount of time sometimes 10mins sometimes an hour then it will just stop and start ticking from the back, on the right hand side.
    But then leave it for half an hour and it’ll run again!
    Any advice would be great,
    Thanks for your time
    mark d
    #259585
    Re: Hotpoint TC71 cutting out
    Classic sypmptoms of start relay failure – you need one of THESE.
    Ticking noise is the heater cooling down. Don’t keep running it, as you’re likely to trip the safety thermostat.
    Power off if you intend to do this yourself.
    md3k
    Thank you very much, i’ve ordered 1 and will be fitting my self.
    Used to work in a tv repair shop so should be ok.
    Thanks again
    mark d
    #259587
    md3k
    Hi there, replaced the start relay but no luck still does the same.
    Runs for a random amount of time (sometimes 10mins sometimes an hour) and then stops and starts ticking.
    Timer keeps running, turn timer to zero ticking stops, turn back to any time setting and press start the ticking starts again.
    Leave it for a while and then try again it will start to work correctly again.
    Could it be an overheating problem as it seems to be when its cooled down it will work again.
    thanks again for any help.
    mark d
    #259588
    helo_75
    unlikely overheat problem, it would just blow cold
    sounds like a timer problem me thinks
    #259589
    grazzamongrel
    when the tc71 starts to play up like you have described then you would be looking to replace the reverse timer on the right hand side ( as you look at appliance from the front ) at the bottom. take off the right panel and it is at the back on the base. you have replaced the relay which would have been my first bet aswell so i would defo try the rev timer.failing that the main timer is faulty but very unlikely.
    #259590
    md3k
    I give it a shot, any ideas on a part number?
    thanks
    mark d
    #259591
    grazzamongrel
    reverse timer is 1701133 and timer up top is 1701746. hope this helps.
