Hotpoint TC71 foam seal
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hotpoint TC71 foam seal
  • #17412
    cornwell40
    Any calls on the part number for the sticky back foam seal that goes around the drum front opening.
    Can’t find the number anywhere.
    Cheers
    TC
    #174150
    Re: Hotpoint TC71 foam seal
    cornwell40 wrote:Can’t find the number anywhere.
    It’s not available as a seperate part. The complete replacement Front Support Assy (Pt No 1701159) is require which comes with a new sticky- backed foam seal 🙄
    #174151
    goosegreen
    I went to my first T/D of this range today.Same fault, Felt seal had come adrift and seized the drum I knew that the heater & stats came complete with the heater box but didn’t know the seal was not available as a spare. The Machine is 18 Mths old and other faults found:
    Front panel not secured to to the side panel with correct sized screws
    Motor fan fouling back panel
    One bearing pad missing
    Belt Fraying
    Very Noisey.
    All in all the biggest piece of junk I have ever come across
    Well done hotmerloni
    You have turned one of the best T/Ds (Creda) in to a pile off scrap
    No wonder its hard to make a living in this game any more 👿
    Rant Over
    Goose
    #174152
    TC71 is a lot older than 18 months, it was either old stock or yours was a CTD, different model altogether. The stats have always been available on their own for TC range. The front panel is not secured with screws to the side panels in any shape or form, the side panels locate on three plastic pegs at the front and three screws at the back plus one underneath on TC models, on CTD models three screws at the back and one at the top front edge.
    #174153
    goosegreen
    Must have been a later model then didn’t get mod number as I knew the job was a no no.
    Goose
