Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint TC71P
- This topic has 9 replies, 5 voices, and was last updated 18 years, 10 months ago by
philt112.
May 25, 2007 at 9:41 pm #27639
philt112
ParticipantHi all
I have the above dryer which has recently had a new heating element and is soon to get a new set of thermostats. i read on another thread regarding these dryers that theres another thermostat inside the door at the top. mine has one but i cant find a spare listed anywhere for it. if i need one where would i get it from?thanks for any info
phil
May 25, 2007 at 9:53 pm #214963hotpnt
ParticipantRe: Hotpoint TC71P
hi, to be honest these rarely fail, i probably fit 100 rear stats to 1 front stat, dont worry too much about it, what problems are you trying to cure?
May 25, 2007 at 9:55 pm #214964aqualectric
Model and serial numbers are required to order parts, (found on the white sticker inside the door or on the back panel). Then click Shop @ at the top of the page. They’ll get it for you; and it’ll be the right one. 😉
Steve.
May 25, 2007 at 10:06 pm #214965helo_75
Participant1701575 is the number your looking for… it rareley fails though, hotpnt has a point
May 26, 2007 at 6:35 pm #214966philt112
well long story really
it started maybe 6-7 months after we bought the dryer. it stopped heating so we calle dthe engineer who replaced the rear stats. then a month or two later it stopped heating again. this time he replaced this single one inside. it lasted a year or so and stopped again so now it was out of warranty i replaced the rear pair myself. worked fine for a while and stopped AGAIN. had a look at the heating element which looked ok but for part of the insulation card? (dont know what its called – the cards that keep the elements apart and the who;e thing rigid) which was broken. left it for over a year then decided we needed the dryer and ive just replaced the element with a new one from hotpoint-spares so i know its the right one. worked for several minutes then stopped heating again. i can only assume its the stats which i reset after the last time it stopped. new ones are on order but if they dont work it must be the singel one. anything else it could be?
cheers for the repliesphil
May 26, 2007 at 6:38 pm #214967philt112
by the way what is the front stat for if theres a stat and safety on the rear? and at what temp does it cut out?
cheers
phil
May 29, 2007 at 7:06 am #214968philt112
does anybody know what the front stat is for on this dryer? does it reset or just is it one shot? if its just another stat then why have 2?
May 29, 2007 at 7:14 am #214969Martin
When the machine “stops” as you put it, then most likely it’s not stat failure at all but the Relay playing up? If however it continues to operate but with no heat, then and only then could it be a stat problem. 😉
May 30, 2007 at 3:02 pm #214970philt112
it was stat failure. replaced them and its working for now. when i said it stops i meant it stops heating. drum still turned. its on now for a testing. see how long it lasts eh? on reading another post on this problem i read about not opening the door until the element has cooled which is what i suspect has happened as the wife likes to make sure things are drying. but id still like to know how the 3rd stat inside the door comes into play?
May 30, 2007 at 3:08 pm #214971Martin
philt112 wrote:but id still like to know how the 3rd stat inside the door comes into play?
No secret, it acts as an exhaust stat (measures the heat flowing out of the machine) If it gets too hot, i.e the air flow is seriously restricted or the internal temperature rises too high – it pops! 😉
