Guys, this is a modded model
just after a little advice.
Went to use it and thetdrum drum didn’t turn
Took washing out and tried again and it worked
With the side off, if I put a little pressure on the drum it cannot start but tries to till I let go.
Once turning I cannot stop it with my hand just slow it down.
I’m going with a start capacitor in my mind but just seeing what you all think?
There is quite some residual heat coming from the motor at the end of my testing, is this normal?
Industrial code 95545710000
s/n 903254225
Capacitor fitted is 4 connector 8uF
Thanks again
Jez
