I have just carried out an heating element change, foam seals, and clean on this dryer and it worked fine for a week. Unfortunately the machine stopped working with no power to the LED. I have power to the PCB but no power to the LED or the machine operation. Can any one shed any light on this other than a new PCB?
Apart from loose wiring connections it could be either pcb, you did fit the cocrrect heater, there are two different ones which are not interchangeable.
Also two different pcbs for both main and facia.
Main one will also need programming first, smart card and card reader needed for that.
