hotpoint tcm570 blowing stats
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint tcm570 blowing stats
  • #57480
    allan73
    This conderser dryer is blowing one shot stats for fun despite being clean as a whistle inside. Drain hole is clear, fans ok, no evidence of water on heater etc & float switch looks good.
    Does anyone know if timer should switch heater off when it reverses as I suspect this could be the problem ?
    Changed the cap by the way out of desperation made no difference 😡
    #331242
    allan73
    Re: hotpoint tcm570 blowing stats
    Can anyone advise me on this ❓
    #331243
    A1engineer
    shoudnt heat on reverse this will be were the problem liies will be a faulty timer causing it to heat all the time.
    #331244
    allan73
    Thanks A1, I had kinda narrowed it down to that but it’s good to have confirmation 😉 , do you know if this is a fairly common problem on these ?
    #331245
    Quite common on the PCB controlled machines, rare on the simple timer controlled ones in my experience though.
    #331246
    A1engineer
    agree its not as common on timer controlled. but does still happen from time to time.
    pcb ones are murder for it tho…
    #331247
    It is simple enough to test for, I use one of those plug in monitors to see if the amps drop when the dryer does the short reverse tumble, observing the electricity meter is another way to check it.
    #331248
    allan73
    Don’t know why I didn’t think of that Iadom 😳
    Ive got a plug in energy monitor in the van, thanks for that.
    Allan.
    #331249
    Its also an easy way to test if a dual/heat element model is working on both sides of the element. 😉
    #331250
    helo_75
    erm, far be it from me to play devils advocate, but who says the heater shouldnt be on on reverse tumble?
    cos, according to the service manual –
    http://img840.imageshack.us/img840/903/switchin.png
    a2-a3 (b3 b5) is the heater switching ( off for the last few clicks)
    the only time the timer would be on is if it never switches the heater off
    unless im reading it wrong that is?
