Hotpoint TCM570G – Tumble Dryer belt tension pulley
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint TCM570G – Tumble Dryer belt tension pulley
  • #63071
    dnaxton
    Good Afternoon All,
    I am after a bit of advise
    The tumble dryer belt tension pulley on my Hotpoint TCM570G has play in it and is rubbing against the bracket.
    How easy are they to replace
    Can someone point in the direct of the correct part as I can’t find one in the shop section.
    Regards
    Re: Hotpoint TCM570G – Tumble Dryer belt tension pulley
    should be part no C00113879
    this is a condensor dryer so you have to remove the fan cover in front of the motor and remove the fan to get at the bolt holding pulley can be a bit tricky to fit since belt is elastic but if you fit back bolt first do not tighten just put in a few threads you can use the pulley as a lever to tention belt pulley then hooks into motor and you can tighten up
    hope it helps plug out first
    dave
    #352472
    dnaxton
    Hi Dave
    Thank you for the swift reply.
    I was looking at that part number as the part looks indentical to the one on my machine. But it didn’t state my model in the list
    http://shop.ukwhitegoods.co.uk/Tumble+D … ulley.html
    I will get one ordered 😉
    Thanks for your help
    Regards
    nop prob m8 some of us saddies are still in work sat night lol
