i have had may probs with this machine 1st one of the thermostats were gone i replaced all of them then the motor was sparking and display flashing on and off and half numbers replaced motor no different then replaced module display now ok but showing f12 help please alan
f12 is non communiction error between the two pcb’s
u mayhave fittted wrong pcb, you cant really fit it wrong, maybe theres a wire off somewhere, maybe u got a duff main pcb,(at the bottom)
but youll need te serial number to obtain the right pcb/ eprom.. and youll need to identify if the drum has a sensing strip round it or not so u can get the right part
The last time I looked at one of these, it had a thermistor and a white spot cut out. Partfinder showed the element with a cut out toc, cycling stat and a thermistor.
When I returned (the cut out had gone oc due to the condensor being blocked as was the filter), it had only a thermistor and a cutout.
The thermistor looked very similar to the cycling stat (button type) it would have been easy to remove the thermistor and fit the cycling stat by mistake. They look identical, the new thermistors are different in appearence now.
If I had changed that by mistake it would have gone oc and the machine would have expected a resistance reading, thus throwing a thermistor fault.
As I said just a thought but its easy to do I am sure.
