Can someone confirm that the start relay also brings in the heater (or not). I have no wiring diagram.
The cut outs and heater are fine. Float microswitch sump empty. I trace the leads back to the relay so am assuming that this controls the heater cct also.
Is the relay a known potential `no heat` fault or is ti the timer?
Lets clear one thing up first, I think we are talking Creda here and not Hotpoint (Creda T620CW) :tup:
The fault more than certain is NOT the Relay in this case but the Timer (1702509) as the heat switch terminal burns out on these beasts more often as not 😉
The only fault the Relay can give you is not starting or starts up then stops after a minute or two.
