Hotpoint td32p Condenser dryer
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint td32p Condenser dryer
  • #73325
    Cane 32
    My condenser drier will start when the button is depressed, runs for about 3 minutes and then switches itself off. The drum is getting hot, the heater is working on both hot and cool settings. Have checked the thermostats at the rear and they appear to be OK. Have taken the side off the machine and cleaned out all debris, fluff etc. After about 15 mins push the start button again, it clicks and then won’t work. PLEASE HELP 🙁
    #387106
    repman
    Re: Hotpoint td32p Condenser dryer
    if you mean TDC32 then the relay behind the control panel is the usual suspect for this type of fault.
    Jim
    #387107
    Cane 32
    Hi Jim the model is a Hotpoint Aquarius Condenser dryer TDC32 what part No do i need for the relay, could you tell me what the relay does in operation of the machine too stop it from working when it was working o.k. Thanks for the help. 😀
    #387108
    A very common fault, THIS is the part you need. 😉
    #387109
    Cane 32
    Hi iadom,
    Thanks for the reply regarding which part No i need for the relay,but before i purchase the part.I tryed the machine again after twelve hours and it started up, it warmed up started normal spin then into reverse then stopped after about 2mins. Is it still the relay causing the problem or is there a stat that i have missed.
    Thanks Again for yours and every ones time. 🙂
    #387110
    It’s the relay, stats do not stop the motor running, it is, as I have already stated a well known fault.
    #387111
    Cane 32
    Hi iadom,jim,
    Just like to say thank you to you both for the infor regarding the problem with my condensing dryer. After ordering the part and fitting it, we are back up and running again and my wife is delighted.
    Would also like to thank UK Whitegoods for the prompt service with dispatching the spare required.
    I will be using you again and shall be telling my friends about the service you provide.
    Thanks again Cane32. 😀 😀
    #387112
    Thank you for updating us. 8)
    ( another Jim ) 😉
