hotpoint tdc 60 dryer
  • #7712
    kingtiffin
    soryy new to the forum hope it s ok to post here got active light on this dryer but heat light wont come on as well as no heat any advice please?
    #124773
    Re: hotpoint tdc 60 dryer
    The most usual cause is the Thermal Cut-out fails, therefore a Thermostat Kit (Part No: 1701583 – Available in our shop@ ) is the most common cure. 🙂
    kingtiffin
    check thermostats and element ok it does this
    active light comes on but wont heat
    #124775
    Did you isolate each one of the thermostats before checking their continuity? If so and they are still OK then there is a thermostat in the door/drum surround (at the top) that may be the fault??
