Hotpoint TDC30 cond dryer no heat. Where is front stat?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint TDC30 cond dryer no heat. Where is front stat?
  • #40076
    Have read here about a front stat on this model. Since everything else checks out OK (I was thinking timer, maybe) can someone please describe where I can find this front stat? Is it a drum out job?
    Ta,
    Mike.
    #264673
    helo_75
    nah
    open the door
    and on the baffle betwwen the door and the drum
    look up, at 12 o’clock and you’ll see it, screwed in with 2 screws
    undo the screws and gently wiggle it out
    be careful the wires dont come off
    #264674
    Re: Hotpoint TDC30 cond dryer no heat. Where is front stat?
    Doh! Didn’t even think of looking up there.
    Thanks for quick reply, helo.
    Mike.
    #264675
    I usually find that it helps to whip the lid off and snip the small plastic tie wraps holding the wiring to the front stat. It just gives you a little more room to ‘wiggle it out’ 😆
    hotpnt
    often the wires to the stat burn out, very rare for timer to fail on these
    #264677
    Just to round this one off, turned out to be a burnt out timer!
    Mike.
