Hotpoint tdc30 dryer -low heat when operated
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint tdc30 dryer -low heat when operated
  • #36747
    haveago
    My TDC30 dryer is working but with only a little heat, from reading other posts I think it may be the thermostat. However my question is if the drying light is still on and I am getting a little heat is it the thermostats or could it be something different i.e heating element?
    I just don’t want to buy the thermostat set if it isnt that which is wrong?
    Also where are the thermostats located on the dryer?
    thanks in advance
    #252166
    Re: Hotpoint tdc30 dryer -low heat when operated
    Unlikely to be thermostats.
    Could be heating element, it has two separate elements in the one unit, could also be faulty High/Low heat switch.
    The only way to check is with a meggar or multimeter, with the plug removed of course. 😉
    Two stats above the element and one inside the door surround. That one can cause poor performance sometimes.
    haveago
    Thanks Jim
    I got a thermostat set to try first as is cheap to buy and fitted it last night and all is back to normal now 😀
    Still not sure why i felt some heat in the dryer initially -maybe just a form of latent heat ❓
    thanks anyway
