Hotpoint TDC30 T/Dryer
  • #17683
    andy2
    Hi does anyone know the cutout temperature of the front stat on these please?
    Andy 😀
    #175750
    Dave_Conway
    Re: Hotpoint TDC30 T/Dryer
    1701575 is the part number on Partfinder but no temp listing anywhere for it Andy 🙁
    #175751
    andy2
    Thanks Dave
    I had an idea it was 60deg and i have one of them in stock, but not sure.
    Andy 😀
    #175752
    Dave_Conway
    I think you’re right TBH, nearly all driers run at 60C.
    #175753
    andy2 wrote:I had an idea it was 60deg and i have one of them in stock, but not sure.
    Andy,
    It has “L78-10C” written on the side of one, so I guess that means its a 78c Stat that resets at 68c? Earlier similar models in the range I know were rated generally at 75c by the way. 😉
    #175754
    andy2
    OK Thank you gentlemen for your help, I will probably play it safe and get the gen stat.
    Andy 😀
    #175755
    Stat 1701575….Open @ 78°C; Close @ 68°C (+/- 5°C)
    Spot on Martin. 🙂
    #175756
    bobokines
    If you have an infra red thermometer, you can read the temperature that this stat cuts in and out by pointing the thermometer at the square rating plate that is situated half way up the back panel above the bearing cover.
    If you run the machine without any clothes it should start cycling within a few minutes. It’s a good test and it impresses the customer. You can tell by this test if there is a problem with the stat, if there is an air leak on the rear drum seal and if the heater is cutting out on reverse tumbles and on the tumble cool setting. (I normally use a clamp meter on the live or neutral lead to the timer to test heater current at the same time)
    I do this test as a matter or course after any repair to to a condenser dryer.
    The thermometer I use is available from Connect part number LAS3540 (£16)
    Bob
