Hotpoint TDC30P Condenser tumble dryer with water leak.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint TDC30P Condenser tumble dryer with water leak.
  • #59500
    FlyingBrick
    Have a Hotpoint Aquarius TDC30P condenser tumble dryer that leaks water from the bottom around the right had side.
    Checked and cleaned out the condenser, checked the water valve on the plastic water collection bottle, black rubber bung taken out of the pipe at the rear and looks clean.
    Sides taken off and fluff cleaned out but there must still be a blockage as the water forms a puddle on the floor and not into the water container. The water is gravity fed so why does it not fall straight into the water container?
    Anybody with ideas where to look next when I go back on Monday.
    FlyingBrick
    #338441
    Allsorts
    Re: Hotpoint TDC30P Condenser tumble dryer with water leak.
    Check there is not a crack in the plastic base where the pump is housed.
    George
    #338442
    No pump on a TDC George. 😉
    #338443
    FlyingBrick
    Is there a pump in the plastic base of a TDC30P tumble dryer?
    Have not taken off the drum yet to dig deeper into the problem George. Will not know until Monday’s visit.
    FlyingBrick
    #338444
    Allsorts
    Ooops .. My bad … No sorry there isn’t.. I’m thinking of the CTD00 … But nevertheless, check the plastics. I just replaced the base on a CTD00 because it had cracks in the base and was leaking.
    George
    #338445
    johnnyj
    you can get them leaking between the plastic duct that is siliconed and screwed onto the back panel, ive sometimes cured with silicon, if not its a bin job as part is obsolete.
    #338446
    HotDog
    Thats the place to look as johnny said i have done this on a few of these just reseal with silicone make sure you use plenty i have had to do it again on one no fun to have to go back
