hotpoint tdc32
  • #18325
    johno1998
    Hi water light comes on I have checked water container but almost empty.Cleaned out float switch it then worked a couple of times, but now back to same fault water light on drum turns but no heat ,any ideas chaps.
    #178587
    Re: hotpoint tdc32
    not sure but i seem to recall that if the stats fail it brings on some of the warning lights if you have not checked them its worth doing so
    johno1998
    Re: hotpoint tdc32
    yes have checked the stats on the heater they are fine ❓
    #178589
    funkyboogy
    Re: hotpoint tdc32
    float microswitch will be stuck on the up position,
    remove rhs panel (mtr side)..microswitch siuated on other side of motor,
    either push long screwdriver over to push switch down or if your hands are small sqeeze hand in…
    this should cure prob…this prob occurs as a result of ir-regular checking of water …
    cheers ally.
    #178590
    johno1998
    Re: hotpoint tdc32
    cheers will try that 😛
