Hotpoint TDC32
  • This topic has 4 replies, 4 voices, and was last updated 18 years ago by PGS.
  • #35445
    PGS
    This M/C heats for about 5/10 mins then cuts out and the dryer light goes off at same time as if it is cycling, before i strip it down could it just be the front stat cheers paul.
    #246520
    Re: Hotpoint TDC32
    Could be, could also be rear stat, timer or even float switch. Front stat pulls down into to drum without any strip down required, often shows signs of burning if it is at fault.
    If it is any help I can send you wiring diagrams for TDC30, uses exactly same timer.
    hotpnt
    Re: Hotpoint TDC32
    hi, when you say it cust out, is the whole machine stopping or just the heat? if its the whole machine it will be the relay up top
    #246522
    PGS
    Re: Hotpoint TDC32
    Just the heat, have checked rear stats and they are 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} ok.
    #246523
    bubs
    Re: Hotpoint TDC32
    Its normally a timer fault
    Graeme
