Hotpoint TDC32 Problem
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint TDC32 Problem
  • #81108
    Rod56
    Hi All
    My TDC32 Tumble Dryer has stopped working.
    It’s been making an intermittent soft grinding noise for a couple of weeks, but still doing its job.
    Now it’s stopped completely. I’ve taken it apart and cleaned all the fluff that had accumulated inside the case and checked the drive belt is working by manually turning it – and if I turn the fan at on the front of the motor the belt goes round and I can see the motor going round.
    But when (carefully) switched on, the motor makes a hum but doesn’t start the drum going round.
    Can anyone help please ?
    Thank you
    Rod
    #415358
    Re: Hotpoint TDC32 Problem
    Replace the 8 mf motor start capacitor.
    #415359
    Moved to correct forum, it’s not a washing machine after all. 😉
    #415360
    Rod56
    Thank you …
    any ideas about the noise – soft grinding
    #415361
    Rod56 wrote:any ideas about the noise – soft grinding
    Check the rear shaft/bearing and the front drum support bearings. Both of which produce the classic “soft grinding” noises we know and love of the Hotpoint dryer. 😀
    #415362
    Rod56
    Thanks – will do
