Hotpoint tdc32 won’t stop turning
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint tdc32 won’t stop turning
  • #86295
    bmrenr
    Hi I have the above m/c and when the dial comes around to zero it does not stop. Has anyone come across this before?
    Tom
    #430740
    Re: Hotpoint tdc32 won’t stop turning
    No, but how do you stop it then, by opening the door ?
    Can only really be a faulty timer TBH.
    #430741
    Andy jones
    Pull the knob off and make sure it isn’t cracked and on in the wrong position
    #430742
    bmrenr
    Cheers guys I have checked the knob and yes by opening the door. I was thinking it was faulty timer myself but said I’d check with you guys on the off chance it could be fixed without buying a timer which the customer won’t be doing I think. The reason I was called to it was because it was tripping the breaker which turned out to be a broken wire to the heater and this must have damaged the timer.
    Thanks again guys
    Tom.
