I have a TDC32P that has no heat and is not drying.
I have changed the rear thermostats (green Spot) with the appropiate kit.
The drying light is not on. The drum rotates in both directions.
Have tested the continuity of the Green Spot Stat, all fine.
Have tested the continuity of the other Stats, including the one in the front door opening, all fine.
Have tested the continuity of the heater, all fine.
Have traced all the wires through to the timer and tested. All fine.
The problem must lie in the timer.
