Hotpoint tdc32s condenser dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint tdc32s condenser dryer
  • #94008
    Galway
    Hi.
    Replaced front and rear bearings on this tumble dryer and it running smoothly now.but the other fault customer was complaining about was the was no water in tray.I have checked and cleaned all relevant parts while drum was out but still no water in tray.the utility room is steamy when machine is running.the door seal looks ok and condenser is clean and seal looks ok.anybody have any ideas?thanks
    #456168
    alster
    Re: Hotpoint tdc32s condenser dryer
    Is the rear drum seal ok?
    #456169
    Yes it does sound like the steam is getting out of the drum into the room so drum seals would be my first check
    Galway
    Thanks for replies.
    I didn’t change rear drum seal as it looked pretty good.I will change it and see if it works.
    #456171
    Have a good look at the front one as u strip it. Had one where the drum was warped and there was no way it would ever seal
    Galway
    Will have a look at it during the week.
